kahoona
Jul 28, 2013Explorer II
Tex, I am glad that you chipped in with that. I have 6 tubes of that (all white) but I never thought of using it because of rule No1 "don't use 5200 if you ever want to get it off again" but actually I don't, do I? I'm going to use just a tiny bead of it so I don't get it on everything else too. That should do just fine! Should be passing through the Panhandle next year sometime. Love that area.
Rule #2 is:5200 is going to get all over everything.you cannot stop it.
I have used it to hold center console grab rails in place and together at the joints. It held until I had to cut the rails to get them off.
Thanks
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
