kahoona's avatar
kahoona
Explorer II
Jul 20, 2013
Ceramic windo tint and aplication questions.
Hi
Because of some suffering in the heat out west we decided to do something. We got a larger but more efficient A/C but could not get a second one because of the 30a wiring. Since I am completely rebuilding and resealing all of the windows I thought we would tint. The films block virtually no light but a large amount of heat so I got a roll of high end nano particle stuff. I have done several sets of headlight protection coverings with 8 mill sheeting so these should be really easy. I do have some questions though if there is anyone who has tinted. Yes I searched but did not find these. Mainly the question concerns coverage. In a car you need to leave a 16th inch space without film where the window rolls up into the top of the track. I plan to simply take the film all of the way to the edge on the non moving half just to make it easy and then put the rubber seal strips and gaskets over it but do I need to leave that 16th" edge where the window slides into the felt end? What about the sides (bottom and top) where it slides on the felt or will it slide under the felt like it does in a car window.
I'll let you know how it works when I am finished but if I am right I will see a reduction in heat while still being able to wake up and see the wild animals roaming about in the dawn light as my coffee maker kicks in.
Thanks
Rob
  • Hi
    Some observations for the next guy. Some troubles that someone might have suggestions to help with.
    I am using SunTek CarbonXP 80 which is supposed to be a Non-Metal, Nano-Hybrid, Carbon Construction with black as its tinting material but very little of that.It is actually a bilious light green like I have seen on the newest Lexuses and I really hate that old Coke Bottle green color. If you are buying then look at some first!
    This is a different animal than the heavy protective stuff that I use for headlights. That stuff stretches and bends and can be formed quite a bit with a heat gun. Very forgiving and when you've got it right you know it and it is there to stay.This stuff has almost no stretch and if wrinkled it seems like it is done for. This is thin and brittle and has to go on right with no wrinkles. You can float it around a bit but you have to be careful. When I first cut the edges they try to come up a bit when cutting. Can I wait till it drys to cut them? I wrecked the first one but the second was easy (unless I mess it up cutting.) Any tricks to making sure it sticks? I am putting it sticky side down (hope thats right) and it does stick everywhere except the edges. Will the edges improve after they dry for a while? I am following the instructions to the letter with new tools bought just for this so I think it will work. Any hints will be great, I'll post pics.
    Rob
  • Just remember, if you have dual pane RV windows, do NOT place tint on the inside, as the heat reflection can and many times does rupture the seal or breaks a pane. NO window manufacturer or installer will guarantee their product or work, if tint is applied to dual pane windows.
  • Thanks all. I'm off to get my Baby Shampoo and stateliness steel razor scraper now! Eric Bounder. Love your rig picture. Its the journey and the things you see along the way makes it so good.
  • I owned a Tint shop for 9 years........and still do tinting on occasion almost 30 years later.....I never did leave a 1/16th gap.........if the edge is trimmed properly there is no need.......let the overage dry real good and with a sharp razor blade bevel the edge of the film and it will not peel......on occasion I would have an edge lift up.....not very often.....
    USUALLY......the outside rubber trim is larger than the inside trim.....so you can hide your cut behind the outside trim so there is no light leak.......
    Some of those new tints are amazing stuff.....it's nice not seeing all of that purple tint nowadays......
    Good luck with your project!
  • The 1/16th gap is not needed anymore.
    Modern window tint bonds really well to the glass.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
