C_Schomer
Oct 07, 2013Explorer
The napa guy tried to talk me into the poly coated lines saying they bent better but I use plain steel cuz I had to silver solder on the correct ends to connect to the hoses. I only used hoses to each caliper. The Parker store had the generic hoses already made up (cheaper) but they were 37° regular flare. The plain steel was a breeze to bend and double flare. I have a Carlisle actuator coming. The first one was damaged. I found out dexter 5200 - 8k uses the same spindles and inner brgs. I tossed my notes but I think my inner brgs are 25580 and the outers are (8k) 02475. I had to buy the 8k outer brgs. The 8k Kodiak hub/rotors came with oil covers and I'm using them - no more packing! I'll send pics if you PM me with a contact. Craig
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
