ice2fire's avatar
ice2fire
Changing shower to a bathtub
DW likes a bathtub instead of a shower. SO, how difficult/easy would it be to convert our shower to a bathtub ? Cost ?
Thanks for any suggestions/ideas.
  • I see the flowing hot water units can be run on electricity or propane. Which is better ? Thanks.
  • ice2fire wrote:
    Housted wrote:
    I have converted two 5ers from 24" x 40" shower to 24" x 46" tub.
    I moved a wall 6" to accommodate the tub. Everyone is right about the water
    heater requirement. One of the conversions has a 12 gal and the other has a 16 gal.
    DW is very happy with the results.
    Photo -> https://photos.google.com/photo/AF1QipPo-Z_FlJaP5-jDE75uV2S68AHzQxDo4GWzJ6Q1
    Housted
    404 error on launch of link. I'd really like to look at them. Can you fix it please?
    Here is a link that should work....
    first of three pics
    Housted
  • Here is a link that should work....
    first of three pics
    Housted
    Those look fantastic ! Thank you. Can I as you what size they are, the bath and surrounds manufacturer ? If I could duplicate those I think my DW would be in heaven ! (And so would I !)
  • The tub and surround are both 24 wide by 46 long.
    The hard thing to find for some reason is the 24x46 surround??
    I got the first tub/surround from the Northwood factory as part of the purchase.
    The second tub/surround came from pplmotorhomes in Texas.
    Good luck,
    Housted
    Good luck,
    Housted
    Thanks. So we're going to do it ! DW agrees, the RV repairman will do any plumbing, another guy, who has experience, will help build the walls etc ! We're going to use frp type walls from Home Depot for the ends and the back.
    So first job is to dismantle the existing shower.
    How does the door come off ? There is a straight piece of metal across the bottom, with three screws in it. I'm going to undo those first !
    Wish me luck.
  • No, I think it makes more sense to remove the U shaped piece of metal that goes all around the top. Is anyone reading any of this drivel ? Am I out on my own - again ?? :)
  • Ice2Fire -- what did you decide?
    If you put one in, can you post pix or give some details?
    THx.
    BTW, we have an Outlaw 37MD (motorhome with internal garage --Toy Hauler). Thinking of purchasing one of the 40+ inch tubs and just stowing it until needed (maybe pulley system to ceiling). Then pull it down and fill from the wash machine hoses when needed. Might put a drain in the floor to connect with wash machine drain -- or something like that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
