time2roll
Dec 22, 2017Nomad
Do you expect a fast charge on generator power? If so you probably need to pull wire to reduce resistance. I recommend #4 marine grade wire.
No generator? the 30 amp IOTA or 35 amp PD will work just fine plugged in. Actually even with a generator these would charge like a rocket compared to the existing Magnetek.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
