RJCorazza
Mar 23, 2015Explorer
My 6.2l gas engine uses 0.5gph at idle without load, and 1.2gph at 1500rpm high idle. Well thought out wiring mod - I like the anderson connectors, which is also how I connect up a 12 fuel transfer pump on my older F150.
My thoughts on TV charging are that it is great to have the truck charging as a backup or emergency plan, but I wouldn't do it on a regular basis. Not because of idling concerns or fuel consumption, but because of the wear and tear on the intermittent duty alternator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
