lawrosa
Mar 28, 2015Explorer
Ok I did the test today and all was great... I am pretty sure I fully charges two 75 ah batts in 4 hours of idle time on truck....
I will post this in sections I guess...
So batts were down to 12.4 or so... took a long time to discharge amd I could not wait. I had all lights on, heat, fans,,,,etc. batteries would not die....LOL/...
So start of test here..
148 f alt... cool ( see red laser dot on windings?) Never got above 180 ever..
Batts down to 12.35... thatswhen I started/.. This is beginning volts.... Nothing hooked up...
57 amps to start
... 50 amp breakers not working???? IDK... This is what I got when I plugged in...
Almost 60 amps not bad huh?
And here is volts
57 amps to start
And here is volts
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
