lawrosa
Mar 30, 2015Explorer
bandit86 wrote:
I thought of this for when im driving, but for boondocking I want a generator. Most generators, say a 2000 watt Honda only put out 8-10 amps dc,
That is an unregulated connection. Why would you consider using it? You would just cook the batterys.
so get a large and I mean large 50 amp battery charger and run it off the generator. I have seen the 200/40/20/2 die hard battery chargers designed to start a dead car bit never had a chance to see at what voltage they charge at. one of those would be almost perfect if one could limit charging voltage to 14.5
Well you can buy your 1000 buck gen and the car charger and test it and let us know .. I did my set up for less then 60 bucks.
Always wondered why generators aren't made a hogh current 14.5 volt output, but then one can build one of these;
http://www.energymatters.com.au/honda-12v-25hp-55amp-battery-charger-with-digital-ampmeter-p-273.html
Why build one? And how much is that? All it is , is an alternator with a honda motor driving it..
I already have one. Its a 4.3 liter vortec V6 with a 105 amp alt...
EDited, if you have a generator all you need is a small welding unit that does dc, or a mig welder. To the whip need to add a large capacitor to clean out the rectified ac into a good dc, then a solar controller to limit output to something a battery can take.
Dont want to weld, most rv converters can do very high currents, about 50 amps dc, its basically a 12v power supply. 150 bucks. Wire into generator and hook all dc outputs to the battery. Probably easiest fix, no need to reinvent the wheel. Maybe even tap into your rv converter you already have, and using a breaker give full dc power to the bbatteries
Sounds complicated. Ill stick with my set up. Thanks for the feedback, but it dont help much IMO...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
