Retired_JSO
Nov 23, 2013Explorer II
Your furnace will be close to 30-35,000 BTU.
I believe, Cheap Heat is about the same as the overpriced 120 volt electric heaters, so called produced by Amish Craftsman, to heat an entire home. The most heat they can supply is just over 5000 BTU. The same amount of heat a $39 Walmart space heater can supply. No where close to 30,000 BTU.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
