pianotuna
Nov 23, 2013Nomad III
Hi Retired,
Actually the 30 amp DH-18 does 1920 watts or 6551 btu.
The 50 amp DH-37 does double that at 3840 watts or 13102 btu
The 50 amp DH-50 does 5040 watts or 17197 btu
This assumes 120 volt power with no voltage drop.
You are right about the costs though.
Retired JSO wrote:
Your furnace will be close to 30-35,000 BTU.
I believe, Cheap Heat is about the same as the overpriced 120 volt electric heaters, so called produced by Amish Craftsman, to heat an entire home. The most heat they can supply is just over 5000 BTU. The same amount of heat a $39 Walmart space heater can supply. No where close to 30,000 BTU.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
