harold1946
Nov 23, 2013Explorer
2-MTnesters wrote:
I was wondering if anyone has converted their factory installed LP furnace to the CheapHeat system. Seems like a very practical system when connected to shore power. No worrying about running out of gas and no hassling with multiple small electric space heaters. Wondering if it heats the coach as well as when using gas. Tim
I installed the system four years ago and am pleased with it. We have been in temperatures down to 14F and had no problem maintaining 70F.
Our motorhome has ducted heat and ducts to the holding tanks and we have had no issues with freezing.
There is probably a point at which it would not be adequate and the LP would be needed, but we have not been in that situation yet.
We are fulltimers and 90% of the time we are off the grid, so I installed an AGS (automatic generator start) system that wiil start and stop the genny as power is needed, controled by the thermostat. If by chance we are on shore power and there is a power failure the AGS will take over.
I would certainly not expect it to maintain as well as my 35,000 BTU LP furnace at below zero temperatures.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
