John___Angela
Nov 24, 2013Explorer
pianotuna wrote:
Hi,
Do you happen to remember what brand of laminate you used? Who did the work for you? Is it 120 volt or 12 volt? Thanks in advance.John & Angela wrote:
under floor (laminate) electric heat
Hi Harold. Hope you are staying warm. Looks like the west got its first cold snap. We are using Pergo Laminate. It's the XP Peruvian mahogany. We did it ourselves. It is approved for under floor heating. In my opinion this kind of heating really just prides warm feet as opposed to heating a room. The two pads we use provide a total of 225 watts over 22.5 square feet. It is 10 percent of the roughly 2400 watts of electric heat spread over 6 locations of electric heat in the coach. 4 in the coach and 2 in the basement. Makes for even warm quiet heat to about minus 5 or so. I like the idea of slow speed forced air systems including yours. Moving air is always better in freezing conditions especially when plumbing is involved.
Hope this helps.
J and A
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
