christopherglen
Nov 24, 2013Explorer
The intake for my heater is in the cabinet under the entertainment center. I wonder if wiring a 1500 watt heater under there dumping heat at the intake of the furnace and running the furnace on low will provide similar results? A relay to kick the heater off when the furnace starts should eliminate over temp issues.
As far as where to buy the fan, go to the website of your favorite big box store, and put window fan in the search box.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
