pianotuna
Nov 25, 2013Nomad III
Hi Christopher,
I doubt the propane would run out in two hours. Nor would I run low on 12 volt power to run the propane furnace. Power failure may be as simple as someone accidentally unplugging a cord by bumping it.
I am redundant for heating. Electric is the first line of defense, then the propane furnace. The RV can use both together if need be.
If necessary I can run the generator, then the V-10 motor for the class C. Of course, for those two options I must be there.
It is a deal breaker for me that cheap heat does not do fail over.
christopherglenn wrote:
If you are worried about failover, then portable or baseboard with thermostats are about the only options. Don't forget AC power goes out, but propane runs out as well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
