harold1946
Nov 27, 2013Explorer
pianotuna wrote:
Hi jc,
Then they should provide it as an extra cost option instead of taking an Ostrich approach.jcthorne wrote:
Yes, an 'auto fail over' would only require the addition of a single relay to the installation. Its just something that very few would have need for so not included in the install kit.
Were the extra heaters and box fans standard equipment or options from Kustom Coach, or is the ostrich approach their SOP ?????
Heat ducts to the holding tanks?
Insulated floor?
Portable generator?
Free standing inverter?
Wider tires?
Solar panels, charge controller?
875 AH battery bank?
Need I go on?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
