Paw_Paw_John
Nov 28, 2013Explorer
2-MTnesters
I to have installed the cheap heat system in my 36 foot Mobile Suite 2004 with three slides. I love this system and I hate some people that talk bad about something that they know nothing about. I used three electric portable heaters and my gas unit at one time and went thru two 7 gallons of propane in one week of camping. I searched for options and came across the cheap heat system and very happy with it. It's going on three years and I keep my camper plugged into electricity while parked at home. I keep my heater set at 45 degrees and have no problems. This system is 100% efficient and that's why you only need so little wattage to keep your camper warm. I camped in 25 degree outside temp and stayed in shorts with the heater set at 68 degrees and was very comfortable. It is easy to install if you have some DIY ability's. This system cost me about $658.00, that the cost of the system and the extra cost for the 30 amp disconnect, 4 inch hole saw, 240 volt wiring. This system is very safe and is built heavy duty for long lasting use. Please let me know if I can help in any way. Good luck!!!,
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
