jcthorne
Dec 17, 2013Explorer
pianotuna wrote:
Hi jcthorne,
21 amps per leg. Actually it is 21.6 amps per leg. If you read the thread carefully if might help.
I was running about 6500 watts @ 120 volts to warm the RV up.
It does not add up. The CH unit (version for 50A systems) uses 21.6A at 240VAC. Does not use 120V at all. In fact will not run off my gen set that is 120v only.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
