TucsonAZ's avatar
TucsonAZ
Chest freezer fridge mod...
Wow, as my first post let me just say the wealth of information (much of which is conflicting) out there is beyond overwhelming. Thankfully I just have the mindset of "let me get started making my mistakes and go from there".
I have been crunching number on my new solar setup and part of being off grid or extended dry campings means major lifestyle changes. Clearly I need to address keeping food cold/frozen and here's what I came up with from least to most efficient:
Stock Norcold fridge/freezer: 6.7kwh per day
Large home side by side: 3kwh per day
5 cubic foot GE chest freezer: 0.5kwh per day (set to #2 which keeps it at 0 degrees)
I can't say I'm totally shocked by this after giving it some thought but it wasn't what I'd expected.
Clearly a chest freeze is the way to go when trying to stay off grid and they make some even more (15%) efficient (based on their number) that fit directly into the stock Norcold hole.
The issue being now you don't have a fridge.
So here's my solution and I would like to know your thoughts.
1) Rivit 3/4 aluminum angle stock all the way around the inside about 18" from the top (looks like this won't interfere with anything).
2) Make a selve out of 1"-2" foam insulation (the type with a backing).
3) Stock the top portion with items you want to keep warmer.
Obviously if you left it like this for a week everything would end up frozen but the idea is to find a balance of use/insulation thickness that the bottom portion stays isolated from being opened and the top portion doesn't freeze (as quickly) due to being opened and isolated from the main cooling area.
This may also allow you to use the stock temp controller.
Any thoughts, input, ideas?
I'm sure you will see a lot of ideas like this posted by me as I get ready to do a couple month off grid adventure with my kiddo. I'm getting my 5th wheel ready now so the ideas are flowing.
As a side note, the price I get for the used Norcold should pay for this entire "upgrade".
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
