tuseggrolls
Apr 13, 2020Explorer
A1RVTraveler wrote:
That would be easy.
Connect the red wire on the thermostat to the Battery + on the battery.
Connect the green wire on the thermostat to the B- terminal on the control box. Add a second wire from the B- terminal to the Battery -
on the battery.
Hook up the 120VAC and everything will run assuming you have also hooked up the compressor, low fan, high fan, white furnace (heat strip) wire and freeze sensor.
The green wire from thermostat is currently connected to GH (HIGH Fan) on the control box?
I just want to make sure.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
