Playtime_II
Jun 19, 2015Explorer
Ours has tile in the galley area and used to have a small area of tile near the entry stairs. When I pulled out the carpet I also removed the tile in the front. They were adhered to a thick sheet (1/4"?) of masonite type material and that was glued to the plywood. Not sure if that allowed HR to install the tile in one shot or not but it made for troublesome removal. I opted to remove them as the edges were curved which I could not find a transition strip that I could use on a curve. I ended up removing two tiles in the galley area (curved and replaced them with spares to squared off the corner and use stock transition strips.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 21, 2026
