Fixed_Sight_Tra's avatar
May 24, 2014
Connect cables from solar closer to converter than batts?
Hello all,
I have a unisolar 136 watt panel and a morningstar prostar 30 controller.
IF I run the wires from the panel down the convenient place above the controller were there are already holes it will add about 5' from the panel to the controller. Then I could easily splice the pos from the controller to the battery cable near where it comes out of the floor to the converter. The neg could then be attached to the bus near the converter. This is probably 5' from the battery and 18" or so from the converter.
The other option is try to run the wires down the front of the trailer to the controller and then to the battery. This will save some run to the battery but it will be a HUGE PITA and will require a lot of drilling into areas that I have no idea what is behind it and tearing some of the fabric off the bottom of the rv to find it near the water tank.
So the question is this. I am willing to loose a little bit of voltage from the longer run, I only use the batts to run the lights and furnace blower and I am mostly just interested in keeping the batt charged when I'm not there but is there a problem with splicing the wires front the controller to the battery cables closer to the controller? This would be a very easy job and wouldn't require any drilling.
Thanks
