Craig95005
Sep 29, 2017Explorer
SoundGuy wrote:
Certainly you can install these 2 pieces as a direct blow system but your existing wall thermostat would then not control the A/C nor would any of the cold air be distributed by the existing ducting. You'd likely also perceive the direct blow installation to be noisier than a ducted system simply because all the noise is concentrated in one area where the A/C is running.
The old unit was way too noisy (including a clanking sound) and the one I bought is supposed to be much quieter. I'm beginning to think the old one was ductless and just used the two ducts as return air. The reason for using the remote is better control over fan speed plus it has a heat pump for heating in the winter which wouldn't have been controlled by the wall thermostat.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
