TenOC
Sep 29, 2017Nomad
As said before the only difference is the inside unit and the thermostat. The outside units are the same.
I have a Atwood non-ducted it one end and a Atwood ducted at the other end of my 5er. I think (?) the the non-ducted inside unit will block the ducts you have with no modifications. Simply install. However, if I am wrong, I do not see any problem with the non-ducted inside unit blowing some air down the ducts.
However, if I were you I would try to swap the non-ducted inside unit for a Ducted inside unit. I think you will very happy with the atwood. You can alway run the ducted unit as a non-ducted unit by closing the slides tabs which open the A/C to fast cool.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
