goducks10
Jan 16, 2021Explorer
I went straight 12V vs 120V and an inverter. Why run the inverter if you don't have to. Yes you can run the 120V fridge on 120V elec hookup while camping. You can run the 12V fridge on 120V as well using the TT's converter.
If the inverter goes out you'll be out of a fridge if dry camping.
Also an inverter draws a small amount of power when running.
I looked at it like using the lights in the trailer. You can use them whether the TT's plugged in or not.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
