CaLBaR
Jan 17, 2021Explorer II
theoldwizard1 wrote:goducks10 wrote:
I went straight 12V vs 120V and an inverter. Why run the inverter if you don't have to. Yes you can run the 120V fridge on 120V elec hookup while camping. You can run the 12V fridge on 120V as well using the TT's converter.
Anyone considering changing to a 120VAC refrigerator with a pure sine wave inverter, should consider getting an inverter/charger/automatic transfer switch. It will make your life much easier !
Remove your old converter. Hook the DC distribution (fuse) panel directly to your battery bank. Connect the inverter/charger/transfer switch to the battery bank. All "shore power" (the external power cord) goes directly to the inverter/charger/transfer switch which then feeds all AC outlet in your RV.
You're done ! No switches to change when changing power !! "Top on the line" models have a separate input for your generator and an auto-start output.
This is what I did when I added the inverter to run the small bar fridge in the outdoor kitchen while travelling. Can keep our food cold outside now and no need to go into the trailer at stops. Works great. Don't even need to think about it since it works automatically.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
