angeladanler's avatar
angeladanler
Cracked roof
Hi friends!
My husband and I recently bought a 1981 Ford Midas that was remodeled back in 2005. Overall, she's in really good shape, but with the first major rain we discovered a leak in the roof.  We found some substantial cracks and have begun trying to dig into it further to figure out how bad the situation is. It appears previous owners have had issues in the same area because of the multiple layers of caulking. There's also a variety of different materials underneath the caulking. So far we have found a mixture of aluminum and fiberglass. Anyway, does anyone have any suggestions or tips on how to proceed with "fixing" the cracks? We're first time rvers and have done a ton of research, but ultimately, we have no idea what we're doing and any tips/tricks/help would be greatly appreciated!
  • Agree with other posters that Eternabond is not a great longer term solution. If you're stuck in the middle of the night with a leaky roof, RV sealant tapes can be life-savers, but other than that, you're likely want to find and fix and gaps on your roof with good quality sealant
  • if it is where aluminum and fiberglass come together under the caulk, then the best you can do is scrape the caulk off as good as you can, clean the two surfaces up with mineral spirits or something to get them clean, then re-apply new sealant.  it doesn't sound like you are talking about holes or cracks in the roof, but rather at a seem, a good picture or two would help a lot to see what you are talking about.
    there is also proper sealants and not proper sealants to use, make sure you use proper ones, and you could even look into better sealants, but they are way more expensive.  as long as your willing to climb up every year and look at the joints and touch up areas than need it, the normal self leveling rv sealant will work just fine on the roof, and non sag on the sides.  one thing though if sealing up around plastic vents and such, find a plastic primer that will improve the bond from sealants to plastic.  to many times I find it just isn't sticking around skylights very good.  THIS is a good one, but there are others, this is just an example of what I am talking about.
    I am not a fan of eternabond tape for anything but emergency repairs myself, it is expensive, and if not installed correctly prone to fail.  I am still waiting for long term results from sun exposure and stuff, I want to see how it holds up after 5 or 10 years.
  • If your description is accurate that the leak has been an ongoing problem and they previous owner just kept slapping a band-aide on it....it probably needs a whole new roof. Once water gets in, it tends to spread and rot well beyond where you find the leak.
    On a 44yr old RV, paying for a new roof is likely more than the RV is worth.
    I see a few options:
     - Keep putting band-aides on it and string it along as far as you can.
     - If you are handy, you could tear the roof off and rebuild it but it's likely to be a big project. I wouldn't try it unless you have experience, which it sounds like you don't.
     - Sell it disclosing the issues but it likely will sell for next to nothing.
  • Not sure if Eternabond would work as I don't know the severity, depth, width of the cracks etc. But it's an option. But fixing it goes beyond what you can see. You should investigate the damage you can't see. Like the wood decking under the roof material, mold etc. Ideally you would want to replace the roof and probably the decking, but given the value of the RV it may not be worth it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
