Cosmic_Artifac1
Sep 29, 2018Explorer
D.E.Bishop wrote:
Here's another suggestion. May save time and energy, contact etrailer.com and ask them if the speed switch they sell will replace the old style remote sensor switch assembly. They are really cool there. I believe the switch has a center off position, three exhaust and two intake speeds.
I've got that crappy auto open/close fan in the back and an on/off multiple speed model in the kitchen.
Yeah that auto open/close feature was just another bell and whistle I didn't need but it came with the lowest amp draw model. I figure already I am going to get rid of that and replace it with the standard crank in its place, the automatic one sticks down too low from the unit anyway and is just annoying. I am also going to get rid of the rain sensor unless I can wire it into switch like the trimmable switch in the video. I already have the reversible switch mounted in my faceplate so that will likely be reused. I might even order a new faceplate and standard crank (yes from Dometic @@) so I can have a clean install with just a PWM rheostat and the factory in/out reverse switch.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
