Artum_Snowbird
Mar 23, 2018Explorer
Take a stud sensor and practice with it to see if you can determine where studs inside the existing window might be.
Another way of seeing whats "inside" is to get up early on a dewy morning and check the patterns on the side.
Look at the door carefully and try to determine how it might come apart. You will need to put in a framework to support your new window, and you don't want it to leak.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
