Artum_Snowbird
Mar 23, 2018Explorer
If you can take the door off and mount it on sawhorses and use a drill press to just press the outside of the other side, move the door around on the level platform to drill all four corners, then punch them in and drill through from the opposite side, then you will have four matched holes on both sides. I would do a practice hole on a piece of wood first, the same thickness of the door, then put a rod in the hole and straighten up the press to be perfect upright.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
