TNGW1500SE
Mar 23, 2018Explorer
joelyn wrote:
lots of good suggestions, the manufacturer does not make this TT any more and hasn't since 2006. masking tape is a good idea. i did buy a metal cutting jigsaw blade which is long enough to cut both sides at one time. not sure if i could cut separately and have the hole match up, lol. the blocking sounds like a good idea and i will see what it looks like once i cut the hole out. again thanks for all the suggestions and will post some pictures when i get it done. thanks again and any other suggestions let me know. might not do until next weekend.
I'd cut one side and then use a drill to transfer that cut to the other side. Long blades bend and you may not be happy ;)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
