Bumpyroad
Mar 24, 2018Explorer
joelyn wrote:MWJones wrote:
jolyn,
Drill those 8 corner holes larger than your bit. Insert the saw blade
through BOTH holes before you turn on saw. Found out the hard way!!
Good luck.
MWJONES, WHEN YOU SAY drill the 8 holes do u mean drill 2 in each corner? like one where the curve starts and ends???
4 holes each side but long bit would be better. practice hole is a good idea. get a look around inside before doing the edges. I think I would go all the way thru with a small bit at first, then use larger bit on both sides so there is no raised area around back side.
bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
