joelyn
Mar 09, 2019Explorer
Super_Dave wrote:joelyn wrote:
.... really never use the shade part. the window is pretty dark so no one can see in anyway plus u have to go outside and open the screen door just to get to the shade to pull down, but looked good when i bought it....
Almost sounds like you installed the window backwards. Is it harder to see out than see in?
Seems about the same looking either way. All The screws are on the inside of the door around the frame and the black smooth frame finish is on the outside. not sure if u can install in backwards unless someone would have the screw side out...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
