JiminDenver
Sep 02, 2015Explorer II
Setting up the solar and batteries JUST to have A/C is impractical. Setting up your rig with solar and because of it being able to run a A/C is not. We do much more with the power than just run the A/C occasionally. We use it for cooking, water heating, cooling, TV/sat, etc, etc. it also is enough power and battery to keep us going for a week of bad weather while on the road.
So if you are installing solar and want to be able to do things, keep that in mind while you design it. even if someone says you can't,
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
