Shawn_outside's avatar
Sep 02, 2015
DC Air conditioner worth it?
I am toying around with putting in a DC AC unit. Anyone have any real time with them? I have an amped 28fs and will be mostly dry camping. I will have solar and 6 volt batteries . Any thoughts? Thank you
  • It's not impossible, it's just that everyone has been told they can't so don't even consider it. ;)
    With a bank like yours and 750w of solar I can run a 5000 BTU window A/C mid day while the batteries sit in float. Get serious and a 9000 BTU mini split uses 600w. I have run it while it's cloudy for four hours. We never need it over night.
    The secret to doing a lot with solar is having a lot of solar to do it with.
  • valhalla360 wrote:
    If you run the specs, you will find that it's totally impractical.
    Anyone who needs A/C also NEEDS a generator big enough to run it.
  • What valhalla360 said.
    After a brief look at some specs, the smallest one I saw requires 11.5A at 48vdc. That would be equivalent to 46A at 12v. A single battery would run it about 1 hour before the battery was discharged to its 50% point.
    The ones I saw were 48vdc. Not too sure how you would get 48vdc in an RV.
    Doesn't seem practical to me.
  • If you run the specs, you will find that it's totally impractical.
    You either get almost no cooling if a very small unit or run times are in the minutes before the battery dies.
  • I don't know how you would ever get enough amps to power it very long! If it was me and I was looking into something like that I would get the roof top swamp cooler. We always thought about it with our last trailer but just brought the genny
    Chris
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 26, 2025
