Macrosill
Jul 30, 2016Explorer
Bill.Satellite wrote:cowboy gypsy wrote:
I have been out of rving for the past couple of years due to family health issues. I'm ready to get back on the road now but before I do , I want to change out my old analog thermostat for a digital. I have a DuoTherm A/C and an Atwood furnace. I know this update has been discussed a few years ago,but I have forgotten the specifics. Any help would be greatly appreciated. Wiring diagram,type and model # of thermostat,etc. would be greatly appreciated.
My current analog thermostat only seems to work when it wants to! Thank you so much in advance.
WHY? Do you think digital cold will be better than analog cold? If you have a bad thermostat it can likely be fixed with an exact replacement unit.
A digital thermostat has 2 advantages. The first is the accuracy of the set temperature. You can enter a specific temp instead of moving a slider close to the number printed on the front of the t-stat. 2nd is how easily you can adjust the temperature differential that controls how far above or below the set temp turns on the a/c or heat.
Set up right a digital t-stat can provide a more consistent interior temperature.
Switching to a digital t-stat made a big difference in the comfortability inside my trailer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
