Terryallan
Oct 25, 2013Explorer II
aarond76 wrote:
Our first camper had non-ducted A/C. The thermostat only controlled the heater. We changed to a digital thermostat from home depot for something like $20 and it was a great upgrade.
Our current camper has ducted air. We would like to replace the thermostat with a digital version. I don't want to lose the low/high fan speed option on the A/C. How are people addressing this?
My Apex came with the Dometic Single Zone LCD Thermostat. It does in fact have hi and low fan speeds, and controls the AC, and heat.
Model # 3313193.xxx Cool/Furnace
It has lo Fan. Where the fan runs continuously, and the compressor cycles on, and off. Ditto for the hi speed setting. Compressor cycles on and off, but fan stays on.
In auto The fan speed will vary depending on the difference between the temp set point, and the room temperature, and will cut off when the set point is reached. I really like that it slows down on it's own.
Hope this helps
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
