If it only controls the heater then you probably have only two wires to deal with. There is no high or low fan to worry about.
Make sure the thermostat you buy can use batteries like two AA or something.
Once you purchase your new thermostat pull the old one off the wall and count the wires. If there are only two wires this will work for you.
- Disconnect the two wires from the old T-Stat
- Drill the mounting holes for the new T-Stat
- On your new T-Stat the RC and RH wires will probably have a small jumper wire connecting them together
- Leave jumper alone and add one of the wires from your RV to either the RC or RH, It doesn't matter which wire just pick one
- Hook the other wire from the RV to the W terminal on the new T-Stat
- Mount T-Stat on the wall, put batteries in and test it.
It really is that simple. It will probably take you more time to drill the two holes and hang it on the wall than it takes to wire it up.
Edit: just realized I didn't specify where to actually hook the first wire. It should go to either the RH or RC terminal and also keep the jumper in place.
