GordonThree
Jan 28, 2017Explorer
Wardster wrote:GordonThree wrote:
I like this $0 solution, of course, only $0 if you have the parts already
Before buying a truck with built in camera, I kept an older gopro on a tiny tripod in the truck all the time. Just turn it on, set it under the trailer's hitch looking up and out, and then back right in. Cellphone already lives on the dash as a navigator, so it's easy to pop into the gopro app and watch the video feed.
What did you do for power? I have a GoPro, but the batteries don't last that long and you have to take it out of the waterproof case to charge it, unless they've come out with something that I am not aware of.
It has a battery, I just recharge as needed. It lasts long enough for hitching up or acting as a spotter for backing into a tight spot.
If you want to use as an indoor fixed camera as demonstrated in the first video above, there's no need for the waterproof case. You can get a skeleton or "frame" case for it that exposes the ports. I have an old blackberry charger I used with mine, ciggy plug on one end, mini-usb on the other.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
