rockylarson
Jul 28, 2013Explorer
I drilled out all of the welds that held it rigid and awkward to store. Replaced them with bolts and wingnuts so it could be taken apart and stored mostly flat. The three pieces are stored under the bed. Dish and its 4 bolts, LNB with short cable and its arm with bolts/wingnuts, and mounting bracket.
BTW, I mount the dish on one of the following:
Fence Post Spike
A short piece of 4x4 held in place by a screw and drilled to match the bracket holes completed the project. It is easy to pound in and remove and extremely stable.
Good Luck.
Fence Post Spike
Good Luck.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
