dtgunner7's avatar
dtgunner7
Dish satellite antenna
Has anyone Permanent mounted a King Pro Premium antenna on their RV. And if so how does it do in the Sun and Weather???
  • rhagfo's avatar
    rhagfo
    Explorer III
    The biggest issue with a permanent mounted antenna is getting a clear view of the southern sky. In the PNW that could be an issue.
  • They are designed to be in the sun and the weather and will hold up for years and years, exactly the same as the units designed to be roof mounted. They are made with the same material. If you figure a way to safely mount it (see if a ladder mount might be a possibility) it will be fine.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
