time2roll
Mar 19, 2021Nomad
Yes I had seen 2.2 as a low cut off but more are listed as 2.5 and I see most of the energy is gone by 12.0 volts anyway. Great information.
Looks like most inverters will take these right to the bottom and still it is far better to stop much earlier.
I am looking at two different uses including an emergency back up for a sump pump that I would allow to run to the BMS cut off vs RV use where longevity for general use is far more important and the lowest voltages would be avoided.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
