Jfet
May 20, 2013Explorer
Hi. I have a thread going in the truck camper section but saw this recent post on a search and thought I would ask here. We are building a flatbed truck camper and were thinking of using the 2" sheets of foam, cut to size. Over the weekend, as we were installing the aluminum siding, I starting to think about spray foam.
It sounds like getting someone to do it is the way to go. Do you have any recommendation where to look and what to ask for? Most of the spray foam installers in this area seem to be doing houses...is it the same material that would be used in an RV? Do they scrape the walls flush such that we can install interior luan over the foam?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
