93Cobra2771
May 21, 2013Explorer
You are correct, it is the same foam used in homes. I don't know if they trim flush to the walls or leave that to the installer - you will have to ask them.
Home installs they usually use a hand saw to bring the foam flush with the wall surface. A good foam guy will have no problem spraying and filling the cavity but not overfilling it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
