Almot
May 24, 2013Explorer III
Spray foam, even of high density, is not totally closed-cell. It does get clogged with water, given a chance - ask boaters. And then it takes forever to dry, in enclosed space in the wall. Luckily for us Rv-ers, it doesn't get a chance to get soaked very often. On the contrary, fiberglass wool gets soaked with water easier, but also dries completely in a few days. Under the floor, however, I would rather use block foam or spray foam than fiberglass wool.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
