ya, I am leaning towards not painting it also, then I don't feel bad if I screw something new to the sides haha
there is an engineering aspect to them also, plus the added benefit of them not moving around.  when they charge at higher rates the casing can expand and swell, so by putting between 4000nm and 7000nm (min/max) of compression on the battery pack, it serves to enhance the lifespan and performance of the battery by preventing internal components from delaminating.  It also helps to manage swelling that can occur due to internal pressure during charging and discharging cycles.
so do you need it, its debatable, the cycle life is based on test of cells than are under compression, so by not having them in compression it stands to reason that it will be affected, and eve recommends compression.   For the average rv use though, where our charging is 55amps at max, then on one 100Ah battery it will make a lot of difference in my opinion, but if you have 900ah like my 5th wheel and your only charging at 55amps then you are only charging at 0.06C and that is pretty gentle on the battery.  so the bigger worry would be from vibration of traveling.  there are also people who claims that most of the damage from swelling is done in the first 5 to 10 cycles so you only need compression for that..
then there is exactly how much cycle life do you lose uncompressed, some claim that instead of 4000 cycles you might get 2500, that sounds like a lot, but it is still 24ish years with two cycles every weekend, which is why the cheep batteries don't worry about it as it is going to outlast their 5 year warranty unless you abuse it which then the warranty won't cover it anyways..
for me the benefits far outweigh the extra work, as I do a lot of off roading to get to places so holding the guts of the battery together with compression just makes sense.  I still have to figure out how to do it in the 5th wheel, what I might just do is make the compression fixture the battery hold down under the steps so I just drop the battery into it and tighten the end down.  I have to get under the stairs and see what I have to work with and come up with a game plan for when I put those ones together.
