so this started because I gave away my first DIY build (280amp) to a good friend, because I also wanted to upgrade the 5th wheel but standardize the batteries between the 5th and truck camper so I ca...
well its all done and the only thing left is to load her up and go camping.
I still need to finish the shelves with a stain/poly coating, but I wanted to get it out this fall and make sure the placement of the shelves and the 1/2" plywood thickness is all good first.
also got a shelf built in the outside storage compartment to go over the plumbing pipe and allow me to put smaller things under the shelf, and bigger things on it.
this was the storage compartment when it originally was turned into a spot for the two 6V batteries.
Now . the front half of the shelf is removable, I had to cut it in to two pieces to get it in so the back piece is screwed down and the front just floats so I can get better access to stuff underneath
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
