agesilaus
Jan 08, 2014Explorer III
If you plan on camping around other people then you better get a quiet generator. You can be sure that a loud construction generator like the one you linked to on Amazon will draw the ire of campers around you. Plus you will have to listen to it too. I doubt that you'll be able to find a quiet inverter type generator of that size for less than a thousand bucks, even that seems to be low. What you need to do is find out how many watts that air conditioner draws plus the other devices you'll be running, and get a generator sized to run that plus some buffer.
BK
BK
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
