Guysakar
Jan 08, 2014Explorer
Matt_Colie wrote:
Guy,
You need to do a lot more research.
RV generators are different because:
They are designed to go into a closed space.
They are all electric start, and don't carry a starting battery.
They don't have a gas tank.
The are better sound controlled than the others.
Few have a demand start feature.
Window air conditioners are a poor application in an RV because the have to protrude through the structure to get effective air flow. This means that to install in a side, they have to be withdrawn for travel. If placed in the leading surface, there is frequently debris/bug issues as they are not protected from this.
I have seen several do as you are suggesting and all would have come out cash ahead to search for a used RV in good condition.
Matt
Thanks for the info. What do you mean about the leading surface and bug issue? I would cut a hole in the side of the rig and fabricate a bracket to "permanently" secure the AC unit for travel.
Why do think I would be ahead financially to opt for an RV AC unit? Pound wise (vs penny wise pound stupid) is the objective here, so saving money in the long run is what I'm about, but I'm not following. Are they more efficient/less time running?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
