Matt_Colie
Jan 09, 2014Explorer II
beemerphile1 wrote:Matt_Colie wrote:
...Window air conditioners are a poor application in an RV because the have to protrude through the structure to get effective air flow. This means that to install in a side, they have to be withdrawn for travel....
Not true, some manufacturers including Aliner use window units from the factory. A cover can be made or purchased to cover the unit while traveling but many simply don't bother. Look closely at my signature picture, the AC unit is forward of the door.
Guysakar, I power my 5,000 BTU window shaker with a little Harbor Freight 800/900 watt generator. The Honda is much quieter though and better quality.
Beemer,
The Alines I have seen have the A/C protruding from the side when parked, but if not withdrawn during travel, are very damage prone (bugs being the least of the problem). Guy is planning to work with a cube van as a start. They are all at least 8' wide so there is no room to leave it protruding when underway without risk. They can be inside, but as they require large areas on both side for condenser air intake, this will kill a lot of his interior volume. If he elects to install it condenser forward, he will take damage from bugs and road debris that the unit was not designed to accommodate. He could add such accommodation, but he isn't through examining is options yet.
In his case, the suggestion of a heat pump roof top unit makes even more sense if he plans to heat - ever.
Matt
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
