time2roll
Nov 21, 2016Nomad
Is that the temperature swing? Or is it just 5 or 10 too high or low?
Mine seems to hold a temperature fairly good but is off somewhat to our indoor weather station attached just above. Mine seems better when cooling but the heat it lets drift a bit low before it calls the furnace.
I had converted mine to the dometic single digital from the analog slider version and the digital is way better but not as good as my home thermostat.
Had not seen the new version posted by Chris above. For $25 I may get the new one to solve an illumination issue. Might even behave better for heating and cooling.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
